After scouring the manuals and newsgroups for possible solutions with no luck, I thought I would post here to see if anyone might have an idea as to what Im doing wrong.
Im trying to enroll a RF5501-433NA keypad with my DSC 632 (PC1555MX CP-01) system. The Keypad manual says that it enrolls as two modules... "1 = keypad section ...17 = receiver section". I entered programming [*][8][xxxx], entered keypad programming[000], selected Partition and Slot assignment [0], and specified [01] as the partition and slot values. I then exited programming, went back into program mode [*][8][xxxx] and did the supervisory reset with [902]. I waited several minutes for the controller to scan the bus...and then displayed all modules with [903]. The only module found/displayed was 1....the keypad. According to the install instructions...17 (the receiver) should have also been found. The instructions say that if both modules do not show on the keypad, then 1) keypad may not be properly connected on the bus, 2) problem may be with keybus wiring run or 3) the keypad does not have enough power. Ive checked all my connections and I'm pretty confident that it is connected properly. My run is short...like..less than 50'...and...I dont know why there would be a problem with power.
Does anyone have any thoughts or suggestions that might help me get the receiver enrolled.
Thanks -- Jeff Gaiche
