Was looking at Axis 207W camera - I see there others but they do not have such great reviews or may not be in my price range
- posted
15 years ago
I have this camera in use for the same reason for almost a year. Take a look at it on
schreef in bericht news: snipped-for-privacy@k30g2000hse.googlegroups.com...
Thanks Kees. Could not look as I did not have admin rights nor Active X component installed. But that is fine. Is that the same Axis camera I mentioned above. DO you turn it off from the PC or just unplug it?
Also do not want it to register my dog (18 inches high) so I would have to tweak the motion and frame settings I am told from the support people at Axis. Guess there are several zones.
I may put it on a remote controlled on/off power switch to electrical outlet. Guess I need to set up a static IP as well. Have not gotten camera yet though.
Thanks for any additional info or comments Sincerely Patty
Kees, Can motion detecion work behind a window or looking thru a window?? I di dnot think it would...
Patty
berichtnews: snipped-for-privacy@k30g2000hse.googlegroups.com...
Patty
snipped-for-privacy@8g2000hse.googlegroups.com...
ups.com...
Thanks so much Kees So very helpful. Patty
