Napco Wireless Gem-PIR
I am trying to use the Napco Gem-PIR with my 9600 board, and I have the following question:
When motion occurs at my other motion detectors(wired) the board very quickly detects zone Open and then zone Closed, and there does not see to be a period where the next motion is not detected for a period of time. In other words if someone is walking back and forth 4 or 5 times it will register Open,closed,open,closed,open etc...
On the other hand with the gem-pir after the first Open and Closed it seems to have a down time where the next motion doesn't register for quite a while. Is this inherent in the Gem-Pir , is it able to be modified?
Any help appreciated.
jjsmd
I don't use the Gem...but
Depends on how they are set, what they are looking at, room activity when testing, mounting height,...etc. Read the directions on what the settings should be. If you're going by the led stay out of the room for 5 minutes or so then walk test it.
Crash Gordon®
Ah..didn't realize it was wireless. Yes, wireless pirs are usually designed to trip only every couple of minutes to save battery life.
Crash Gordon®
Wireless motions will usually go dormant for about two to three minutes after they've detected motion. Actually only the transmitters usually go dormant but not the sensors. The following scene will demonstrate how it works:
The PIR is sitting there for an hour and someone walks into the room as a party begins. The motion detector, sensing them, will trip once. For the next 4 hours there is no time that the "detector" isn't sensing motion. However, the unit will not *transmit* another open signal to the transceiver for that whole period of time. At the end of the party everyone leaves the room. Not until two or three minutes after the last person leaves will the detector be able to send another open signal to the transceiver. As you can imagine, if this weren't so, you'd be changing batteries in wireless PIR's every week or so.
Jim
Wireless PIR's fall asleep for a couple of minutes after each activation to conserve the batteries........ Regards, Russ
Russell Brill
Thank you all for your replies.
I did not realize there was a 2 or 3 minute dormant period.
Thanks
jjsmd
That's done to conserve battery power. Without it the battery would be quickly exhausted in a room where there is a lot of motion.
Robert L. Bass
My guess is the reason for that is because they make no mention of it in the motion installation guide
Mark Leuck
1-way wireless detectors do this to maximise battery life. Some wireless detectors actually increase this delay after each activation upto a maximum delay usually documented somewhere (but sometimes not). So, after the first activation the detector may go to sleep for 30 seconds, if another activation occurs within that 30 seconds then the detector goes to sleep for 1 minute and so on. Sometimes up to a few minutes. This can make arming the panel a lengthy process as the detector may not be active after arming for a few minutes. In cases such as these for maximum security the property owner usually has to wait around a couple of minutes after arming commemces for the detectors to be fully operational.
In low traffic areas that detectors sleep time is kept low on variable delay systems.
2-way wireless does not suffer from this problem as the alarm panel can tell the detector to wake-up or go to sleep depending on the arm status of the panel. This is usually immediate regardless of the number of activations at the detector prior to arming. Conversly, when the panel is disarmed the detectors never activate (unless they are 24h types). 2-way systems conserve battery power in this way and generally get longer battery life as a result.
Ooops. Very long reply. Sorry.
Roger
GEM PIRS act exactly that way to save batteries. The thought being if the alarm is armed and the system is active it only needs to trip once from an intruder. Not over and over again.
If you put it in walk test mode you can activate it repeatedly for a couple minutes to check its coverage.
Bob La Londe
