Napco panel master code question
Threaded View
First, thanks to everyone who has helped me with questions regarding my Nap
co alarm system.
I have the quickloader software and am able to upload and download with no
issues.
I have a P3200 panel and I see a master Security code, download security co
de, dealer keypad program code on it.
My parents have a Gemini 816 panel and I only see a download security code
box no Master.
If we ever needed something done to the 816 panel that I could not do and t
he installer needed the code they could change it and lock us out since the
re is no master security code? Am I correct? Why is there no Master securit
y code on the 816 or is there a setting I need to do to see that appear on
the quickloader?
Just trying to be careful so we don't get locked out in the future if someo
ne works on the panel?
Thanks in advance.
Re: Napco panel master code question
On Monday, May 13, 2019 at 9:58:00 AM UTC-4, szig...@gmail.com wrote:
apco alarm system.
o issues.
code, dealer keypad program code on it.
e box no Master.
 the installer needed the code they could change it and lock us out since t
here is no master security code? Am I correct? Why is there no Master secur
ity code on the 816 or is there a setting I need to do to see that appear o
n the quickloader?
eone works on the panel?
I'd guess that it was just the manufacturers choice not to provide as much
security on a less expensive panel.
Also, you have to know that the manufacturer (Napco) is not typically consi
dered a DIY friendly company.
Site Timeline
