Hello,
I have an older Ademco Vista 50P, about 14 years old. It is working just fine but I have mad a major mistake. I initally programmed the panel from the alpha keypad, all was working just fine for all these years. I then decided to make changes, and decided to use the Compass Downloader to make the changes. Many years ago, I downloaded and saved the data from the panel, but until today, I never did an upload. I assumed, that when I opened my customer data, then connected, then did an upload, the upload data would be the customer data, which is where I made my changes. I could never have been so wrong. From the View menu, there is a very big difference from View/Upoad and View/Saved. View/Upload is pretty much empty, no data whatsoever, so as you may have guessed, I have now basically set my panel to being not programmed at all. Not good. My Compass version is 1.5.8.44. I have tried till I am blue in the face to change the Upload data, nothing seems to work. How can I upload my saved data in to the panel ? There is no help at all, only Help/About, that is it.
Any and all help is greatly appreciated.
TDM
Posted Via Usenet.com Premium Usenet Newsgroup Services
---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
