My goal is to equip the new house with alarm system which is monitored by the central station. I am new to security systems, but once I started learning about them, my DIY personality started leaning towards building a system myself. By doing some research in this discussion group I learned that alarm systems communicate with the monitoring station by sending CID signals. If CID is a DTMF sequence, can I generate it using any DTMF encoder? If I know the CID format that is expected by the monitoring station, does this mean that I can have a computer to control a DTMF encoder in order to send code sequences to the monitoring station? Is there any response from the monitoring station that I need to listen to, or I can be in "transmit only" mode? Is there any spec to CID tone length, pause between tones, or any other restrictions? Thank you.
- posted
15 years ago
