The system has: LCD4500 Keypad PC4216 Low current output module Escort4580 module T-Link TL250 Network Internet Alarm Communicator
The entire system works perfectly fine except for communicating. The custom er had me set up the system to email him using the T-Link. He had me set up the system to send emails upon arm/disarm and violation. I guess he wanted to track his wife's coming and going. It all worked just fine then one day it stopped sending emails.
Now, the system all works just fine but it won't it won't send out via T-Li nk. I tried switching the direction to dial out instead of going via T-Link . It won't dial out either. I use a Magicjack for testing the system. Magic jack worked fine as a dial tone generator in the past (the place does not h ave phone lines). I listened in on a hand-set phone and when I put the pane l in alarm, it doesn't pick up or try to dial.
I've been working on this system for a long time and cannot find anything t hat's wrong with it. I'm about to start replacing parts but thought I'd ask you guys for help first.
Any ideas what I can check?
Thanks for your help!
