I'm looking for recommendations on a garage door opener keypad. I normally use a wireless remote / homelink to operate the door, but I want a keypad as a backup, so that someone cannot be locked out of the house.
My requirements seem simple, but I've had no luck with finding a unit that meets them:
- Wired - it will activate the door by triggering the manual pushbutton circuit
- No batteries - it must be A/C powered. If it has a back-up battery, for in case of power failure, that's fine, but I don't want the unit to fail because the battery died.
- The relay must be separate from the outdoor keypad. This would prevent someone from simply ripping the keypad off the wall and shorting the wires going to it.
- It must be reliable
A unit exists that meets all of the above requirements except one: a Genie KEP-1. I've got one of these. In fact, I've had 2, and they have both died. The first one lasted many years, but it eventually stopped working. I bought a new one of the same model, and it died within the first year. I even had the power adapter on a surge suppressor, since I suspected that might have killed the first one. I it listed on Amazon, and from reading the reviews, it seems many others have had reliability problems with the KEP-1.
So I'm looking for a similar device, but one that will last more than a few months. It seems that everything else I find is battery powered, and most of them are wireless. Any suggestions would be greatly appreciated.
