It's probably an OnQ box. He'll also need an OnQ mounting plate for DSC. It's a standard item and it affixes to most OnQ cabinets. The same OnQ plates for DSC will also fit in a ChannelPlus (aka OpenHouse) structured wiring cabinet.
Those only function if the lightning strikes just as you reach 88 mph.
And they must be rated for 1.21 jigawatts.
Does that plate come with somekind of protector/barrier to keep other stuff from contacting the circuit board?
I use OpenHouse swbs a lot and which I could find something lilke this for other products (I don't do dsc).
R.
| Bass Home Electronics | 941-866-1100 | 4883 Fallcrest Circle | Sarasota · Florida · 34233 |
HIJACK ANY SOFTWARE AT MNONITRONICS, TEXAS YET? ARE YOU STLL EMPLOYED AS A DOWNLOADER FOR THEM AS PER YOUR BLOG HERE?
I am unfamiliar with that city.
OnQ makes mounting plates for several other alarm brands. AFAIK, they all fit ChannelPlus. Check with ChannelPlus tech support first. IIRC, the number is 800-999-5225.
Regards, Robert L Bass
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D>
941-866-1100 4883 Fallcrest Circle Sarasota =B7 Florida =B7 34233hahahahahahahaha
Not really, RLB just spouts bullshit, Mike is really nuts
Saaay, do you work in my area? I see a lot of that kind of work around here ;>>>>>>>>>>
It's a suburb of Dallas.
They're both bullshitters.
But Mike really believes his bullshit, RLB just spouts off what sounds good
LEUCK, HIJACK ANY DOWN LOADING SOFTWARE FROM YOUR EMPLOYER YET MONOTRONICS IN TEXAS?
FIND ANY SPOOKS YET SCOOBY DOO?
