Does anyone here now how to run autoconfig on this panel? When I try to run it I get an "access denied" message. The 7200 program manual says to log in with the level 4 code to run the config program. I have done this, but once it starts the autoconfig about 2 seconds later it comes up with access denied.
One thing I noticed is the user codes are only 2 digits and the manual says they should be 6, so I think its a 7200 Micro control but im not sure. I contacted a local FCI dealer "the original installer" and they told me the panel is no longer made and they are not sure they have a tech that knows how to program it still. They did say they would send one out and quoted me 10 hours @135 per hour. I am only trying to add 1 monitor module to the system. The current system only has 5 points on it now. Needles to say the dealer isnt intrested in such a small task, or helping me out.
Can anyone tell me the correct procedure for running autoconifg?
James
