Everything for years was ok with compass downloader untill i decide to build a new pc. I install compass and set up the modem (ademco cia) for ademco and for fbii panels. What happens is that i can only work with fbii panels. When i am trying to call an ademco panel, i hear the dial tone from the modem's speaker but thats all! It doesnt dial and i get an error message (no dial tone-error result code 6)! Any idea??? thanks in advance
is the proper modem selected for ademco panels in the modem preference section I had mines set wrong this way it was fine fbi but had it set wrong for ademco
section I had mines set wrong this way it was fine fbi but had it set wrong= for ademco
I have set it for ademco panels at physical com port 1 (com1) as ademco cia= 2400 and for fbii panels as ademco cia 2400 for fbii. The strange is that = everything works ok and after i made format to my pc and reinstall compass = i cannot make the admco cia modem to dial for ademco!
e section I had mines set wrong this way it was fine fbi but had it set wro= ng for ademco
ia 2400 and for fbii panels as ademco cia 2400 for fbii. The strange is tha= t everything works ok and after i made format to my pc and reinstall compas= s i cannot make the admco cia modem to dial for ademco!
wow thats really strange is there a chance the compass program is corrupted= it did not fully install may want to reload it
nce section I had mines set wrong this way it was fine fbi but had it set w= rong for ademco
cia 2400 and for fbii panels as ademco cia 2400 for fbii. The strange is t= hat everything works ok and after i made format to my pc and reinstall comp= ass i cannot make the admco cia modem to dial for ademco!
ed it did not fully install may want to reload it
maybe... cause sometimes while opening communication tab even on an fbii pa= nel or an ademco, i get an error message in "chinese" (unrecognized charact= ers!) I'll try to reinstall it again from another source, not from my cds but dir= ectly downloading it from ademco library.
odem preference section I had mines set wrong this way it was fine fbi but = had it set wrong for ademco
co cia 2400 and for fbii panels as ademco cia 2400 for fbii. The strange is= that everything works ok and after i made format to my pc and reinstall co= mpass i cannot make the admco cia modem to dial for ademco!
pted it did not fully install may want to reload it
panel or an ademco, i get an error message in "chinese" (unrecognized chara= cters!)
irectly downloading it from ademco library.
very strange... i am using compass 1.5.8.55 and i want to uninstall it and install the new cmp2014 but i cannot found uninstall button or i cannot locate cmp1.5.8.55 at add/remove programms!!! Also if i'll install the cmp2014, i read that it doesnt support vista12D, 4110XMP, XL2S etc! What the f*** is this?
You don't need to uninstall the old Compass although it will likely no longer work when 2.0 is installed. If you want to remove it you can just delete the Compass directory although you then lose your database
the Vista-12 and 4110XMP if i recall come with the Canadian patch, as far as I know the XL2S has always been supported, it may be listed under XL21
