I am looking at having a DSL line installed at my house that would be using the same telephone line as my Napco Magnum 1000. The Napco currently does nightly self-tests which "seizes" the phone line in the house when it is performing these tests. My concern with the DSL line is that the DSL link will be dropped every night as well when the Napco does its self tests.
My question is the following. If I split the phone line at the demarkation point where one branch goes only to my DSL modem and the other branch goes through a DSL filter and then to the Napco and the rest of the house, will the Napco still be able to make its nightly self-tests where it seizes the phone line, but doesn't drop my DSL connection?
ie:
Demarkation pt ==============[ Splitter ] phone line |=====[DSL Modem] | |=====[ DSL Filter ] ------- [Napco Magnum 1000] ----------[ rest of house ]
A friend of mine currently has a DSL connection on a regular line (no Napco), and sometimes uses a 56k modem on his computer to dial up to other servers. If a 56K Modem is able to dial up over the DSL line, does this imply that the Napco should be able to as well? I am assuming that Magnum
1000 just uses a regular modem to communicate with the centrale - is this a valid assumption?Thanks for the help.
Eric
