I cannot change the master user code on a new one Nx6 panel. I can only do it from DL900. From keypad with *8 and master code does not do anything...?! Any ideas?
- posted
13 years ago
Check for a field in DL900 which prevents allowing keypad programming many of the newer panels have this feature.
To change the master code you do not use *8 you use *5
Done.
Les
Yap right i wrote it mistake. I'm doing it correct with *5 but its been a long time not installing caddx panels and this is a new one so i'll check DL900 for this field. Its a new one panel.
I'm finding all kinds of new tricks to learn with the new 9th addition fire panels as many fields have been changed or eliminated. especially in the combo panels.
ote:
=CE=BA=CE=B5=CE=B9=CE=BC=CE=AD=CE=BD=CE=BF=CF=85 =CF=83=CE=B5 =CF=80=CE=B1= =CF=81=CE=AC=CE=B8=CE=B5=CF=83=CE=B7 -
=BC=CE=AD=CE=BD=CE=BF=CF=85 =CF=83=CE=B5 =CF=80=CE=B1=CF=81=CE=AC=CE=B8=CE= =B5=CF=83=CE=B7 -
The "problem" with caddx is that every new version you have to guess in the DL900 which new segments become alive from "reversed" :-)
