http://208.56.221.39/Invision/index.php?showtopic=630&hl=brinks One5ft2QT
*Posted:- Apr
Unregistered
Hi there...We have a Brinks alarm/keypad hooked up to our home that is not currently monitored...We think a friend of a friend may have gotten access to our master code. Does anyone know how we can change our master code? How about deleting an "extra" (auxiliary) code? We followed the instructions on the user manual from this website, but it's not doing what it it says it should do after pressing our master code sad.gif
Can ANYONE please help us and/or give us suggestions?
Thanks!
Top
Tx Tech
*Posted:- May
Unregistered
What are you doing and what does it say?
Based on the Users Guide, the steps are: Press Options until Auxiliary codes appears. Enter Master Code. Enter the auxiliary code slot you want to access from # 1-6. The screen should now say enter new code. To add or change codes enter new code. To remove hit Cancel and that erases the code.
You will not be able to change the Master Code unless you pay Brinks to come out and change it since there are minimal user programmable features other than Test, Auxiliary Codes, or Chime.
