How did you end up with all that gear and no technical support? Do you have the D6200 Programmer software? I assume you have all of the proper licensing for the IP portion of the D6600 receiver? At its core a D6600 is meant for monitoring alarms via the regular dial up telephone network. The IP part is more or less an afterthought to the D6600, as it is with may other brands of receivers. There is a lot of stuff you have to do to get it to work right. Since I don't commission a D6600 everyday, it would be best to get some support from those that do. In fact I have only commissioned D6100 units, not D6600 units. Here it is step wise.
1 ? Bosch Control Panels
2 ? Connection ? Control panel serial device interface (SDI) bus to D9133TTL-E or DX4020 SDI Terminals
3 ? D9133TTL-E or DX4020 Network Interface Module
4 ? Connection ? D9133TTL-E or DX4020 Ethernet port to Ethernet hub
5 ? Host PC running D6200 Programming Administrative Software
6 ? Connection ? Ethernet hub to Host PC NIC
7 ? Ethernet hub
8 - Connection ? Ethernet hub to D6100i
9 - D6100i
10 ? Connection ? Ethernet hub to D6680/ D6682
11 ? D6680
12 ? Connection ? D6680/D6682 to D6600 COM4 port
13 ? D6600
14 ? Connection ? Second D6680/D6682 to D6600 COM1 port (optional)
15 ? Connection ? Ethernet hub to second D6680/D6682
D6200 Network Connection Connect the D6200 software to the network through the D6600 COM4 or COM1 port or the D6100i Ethernet port. One receiver can communicate with three different PCs running the D6200 Programmer Software.
6.4.1 IP Address 1 Selections: (xxx).(xxx).(xxx).(xxx) This entry is the first IP Address of the computer running the D6200 software. Set the IP Address to a unique value to distinguish it from other stations in the network. This value must match the D6200 software network settings. Use an alphabetic key (A to F) to add a decimal point (.) when programming IP addresses from the keypad.
6.4.2 IP Address 2 Selections: (xxx).(xxx).(xxx).(xxx) This entry is the second IP Address of the computer running the D6200 software. Set the IP Address to a unique value to distinguish it from other stations in the network. This value must match the D6200 software network settings. Use an alphabetic key (A to F) to add a decimal point (.) when programming IP addresses from the keypad.
6.4.3 IP Address 3 Selections: (xxx).(xxx).(xxx).(xxx) This entry is the third IP Address of the computer running the D6200 software. Set the IP Address to a unique value to distinguish it from other stations in the network. This value must match the D6200 software network settings. Use an alphabetic key (A to F) to add a decimal point (.) when programming IP addresses from the keypad.
6.4.4 Reserved Section 6.4.4 is reserved in Firmware version 1.32 and later. Typically, the port numbers 0 to 1023 are reserved in UNIX systems for specific applications. Use numbers ranging from
2000 to 30000 to avoid conflicts.
6.4.5 Network Programming Enable Default: 0 Selections: 0 or 1
0 Disable network programming.
1 Enable network programming. Use the D6200 to program the D6600/D6100i CPU, line card and other network communication parameters through the network connection.
6.4.6 Network Report Enable (Reserved Feature)
6.5 Network Printer (Reserved) Section 6.5 is reserved.
Good Day
I have the panel D7412GV2 (Bosch), I need to monitor my panels using DX4020 D7412GV2 and D6600; I am doing the configuration as shown in the "guide of D7412GV2 trouble" but I can not monitor the alarm panel, please Show me what parameters set in D7412GV2, DX4020 and D6600 panels in order to monitor the network.
thank
