battery replacement
I am renting a condominium and the main control panel of the security system started beeping every 45 seconds. This seems to indicate that there is a battery low in one of the wireless remote sensing devices. There is only one device so I took the cover off of it but I cannot see a battery. Any idea what I am doing wrong? I don't want to break anything so I'm not prying anything off. The system seems to be a Honeywell Ademco or something like that.
Any advice would be appreciated.
tbil99
Call the landlord and have them fix it
Doug L
Doug L
It would make more sense for me to replace it if it is easy to do.
Anyway, I pushed the Off button and then the lcd started flashing "Not Ready". When I pushed the Ready button again, it still flashed "Not Ready".
tbil99
One device and no battery? Hmmm. What did you pull the cover off of? If it's a low point battery it will show you a point/zone number. Code + Off will stop the beep.
Crash Gordon
alarman
Trust us, it makes no sense for you to fix it yourself
And above is the reason why
Mark Leuck
