Ademco 4115 System with 6127 Console Problem
Hi all,
Have had a problem come up on the display of my Ademco Alarm Panel (6127 Console) Yesterday and is still there today, it is flashing BAT which I assume means Battery (don't have manual) every few Seconds, I changed the Battery with a brand new one this morning and tonight when I got home it is still flashing.
I am just wondering if anyone else has had this problem and can maybe point me in the right direction to fix it? The system still seems to be working fine apart from the BAT flashing on the display.
Thanks in advance for the help.
Regards,
Kevin
Kevin Densham
Try: Code + Off, then Code + Off
Crash Gordon
Thanks for the reply, I just tried what you suggested, I am thinking of doing a full reset on the system but I really want that to be a last option.
I am now wondering if I have something wrong with the Charging Circuit in the Panel, when I remove the new Battery from the Panel its measuring
12-13V and when I measure the Terminals the Battery plugs into on the Panel I am seeing 14-15V but when the Battery is plugged back in the Voltage drops back down to 12-13V off the Panel.
Anyone got any ideas? If the Charging Circuit is blown I would not know what to change as I don't have Schematics for this System, thanks.
Regards,
Kevin
Kevin Densham
All sorted, done a cold reset on the system and plugged it back in and the problem seems to be fixed, thanks for the help.
Kevin
Kevin Densham
That panel only tests the battery once per day, If you wait 24 hours the message should go away. If it dont you could have problems with the charging circuit.
James
J Barnes
