just go into user code programming and write down what the codes are. I think it is the *5 Menu
James
James
If you're really interested in security...why are you using a Simon anyway? js
Yup, I thought you had a 5500 keypad. :)
James
Yes, Or any other code you want to look at.
James
"James"...
Either I'm lost or you are. As far as I know, the only code that the panel will display is the master code.
I know that if I logged into the panel through DLS I could get the codes, but that wasn't even possible in this case. As it turned out, there were only two codes anyway, so it wasn't a big deal to get the list.
In the future though, it would be a very nice feature to use.
Why wouldn't it be? It would be at least as secure as the master code anyway. And if you already have that... the system is pretty much all yours anyway.
What I don't find secure is programming codes into Simon systems and it tells you the code verbally. I try not to do much programming if there's anyone home, or at least in the room.
......or are you thinking of the LCD-5500 keypads? We typically use the LCD-5501's instead (some customers would be too easily confused with words and instructions anyway), but if this is possible with the 5500, I may have to keep one in the car.
so with the 5500 i could just go * 5 master code 01 and get that code?
The most time I spend with them is on Simon 2 takeovers. It seems that there must have been doorknockers in the area a few years ago looking for elderly people to sell a contract and some peace of mind to. I'm not sure if it's good or not, but I've only had to turn one motion detector right-side-up (it spent three years watching the ceiling).
As far as security goes, I never have liked the Simon systems, especially when the phone jack is usually either not used (and hence no line seizure) or in plain sight. At least the Allegro has dealt with that issue.
Generally we'll use them when we either haven't seen the home and can't get a good description of it (out of town, old houses, etc.)... or when we simply aren't able to run any wire at all (especially log homes).
As far as fully wireless systems go, it could be worse... could be a Snif system :)
good to know... thanks james :)
Including the installer code and the downloading code? I am not sure these are available in this way.
You can view the installer, master code and downloader code in binary
No, Just the user codes can be viewed in the *5 menu. You need to enter programming *8 to view the installer and download codes. :)
James
I'm certainly no expert, but I don't quite understand how you can _see_ the installer code with *8, since you first need to _enter_ the installer code after hitting *8.
You can view the installer code but only after using it to get into programming first
