Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Lew on February 24, 2006, 7:42 am
Please log in for more thread options X10 system where a Netgear wireless network is already operating? thanks for any info Lew | ||||||||||||||||||||||||||||
Posted by Dave Houston on February 24, 2006, 8:36 am
Please log in for more thread options modules and switches use 120kHz on the powerline and 310MHz for wireless. If you're talking about their wireless cameras, etc. I think the consensus opinion is that they don't work very well even in the absence of interference. | ||||||||||||||||||||||||||||
Posted by Neil Cherry on February 24, 2006, 12:57 pm
Please log in for more thread options On 24 Feb 2006 04:42:24 -0800, Lew wrote:
> Since they both use 2.4Ghz, is there a problem with trying to set up an
> X10 system where a Netgear wireless network is already operating? Since it sounds like your talking about the X10 Wireless cameras that operate at 2.4 GHz, then it is my understanding that you will have trouble as the X10 wireless camera uses the entire 2.4GHz range. I haven't had the camera on while my 802.11 network has been running so I can't say for sure. As Dave was pointing out the X10 power line controllers and modules do not interfere with the 802.11 network and the handheld RF devices don't interfere with and 802.11 network either. -- Linux Home Automation Neil Cherry ncherry@linuxha.com http://www.linuxha.com/ Main site http://linuxha.blogspot.com/ My HA Blog http://home.comcast.net/~ncherry/ Backup site | ||||||||||||||||||||||||||||
Posted by Lew on February 25, 2006, 7:53 am
Please log in for more thread options Aha! The X10 stuff should work okay if I use 110V-outlet-based
equipment, eh? Overall, what is your opinion of how the X10 equipment works when being controlled by a computer? I want to have a system that mainly controls lights -- dimming, and turning on when someone walks into an area (temporarily lighting up stairways, etc.). I'd also like a pseudo-emergency setting that turns on all the outside lights and many of the inside lights. While I'm at it, I think I'll have the computer control the four HVAC zones in the house. Thanks, Lew Neil Cherry wrote: > On 24 Feb 2006 04:42:24 -0800, Lew wrote:
> > X10 system where a Netgear wireless network is already operating? >
> Since it sounds like your talking about the X10 Wireless cameras that > operate at 2.4 GHz, then it is my understanding that you will have > trouble as the X10 wireless camera uses the entire 2.4GHz range. I > haven't had the camera on while my 802.11 network has been running so > I can't say for sure. > > As Dave was pointing out the X10 power line controllers and modules do > not interfere with the 802.11 network and the handheld RF devices > don't interfere with and 802.11 network either. > > -- > Linux Home Automation Neil Cherry ncherry@linuxha.com > http://www.linuxha.com/ Main site > http://linuxha.blogspot.com/ My HA Blog > http://home.comcast.net/~ncherry/ Backup site | ||||||||||||||||||||||||||||
Posted by Neil Cherry on February 25, 2006, 6:23 pm
Please log in for more thread options On 25 Feb 2006 04:53:41 -0800, Lew wrote:
> equipment, eh? > > Overall, what is your opinion of how the X10 equipment works when being > controlled by a computer? !@#$% you just threw a hand grenade into a mine field! ;-) I'm one of X10's critics, it can be tempermental but can be controlled. While I can control the sending and receiving of signals I can't control X10's quality (other venders have better quality). I have a switch in the garage that needs to be 'woken up' by manually using it every once in a while then it works fine for months. I don't think it was meant for a garage environment (near outside usage). Also their lamp module has a high bulb burn out rate (certain low watt bulbs purn out faster if on a lamp module than on an appliance module). > I want to have a system that mainly controls lights -- dimming, and
> turning on when someone walks into an area (temporarily lighting up > stairways, etc.). I'd also like a pseudo-emergency setting that turns > on all the outside lights and many of the inside lights. > While I'm at it, I think I'll have the computer control the four HVAC
> zones in the house. This is just a matter of getting the correct hardware and software. But you'll need to do some programming. How much progamming depends on the software you use. -- Linux Home Automation Neil Cherry ncherry@linuxha.com http://www.linuxha.com/ Main site http://linuxha.blogspot.com/ My HA Blog http://home.comcast.net/~ncherry/ Backup site | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| x10 vs wireless network | February 24, 2006, 7:42 am |
| Wireless network hassles | December 24, 2005, 4:23 am |
| Need wireless network camera, easy to use and small | March 28, 2007, 6:33 pm |
| HAI Network Library | October 10, 2005, 11:26 pm |
| Network Wiring: A or B? | January 31, 2006, 6:44 pm |
| Phone and network Punchdowns | February 27, 2005, 11:01 am |
| Network & TV cable question | July 21, 2005, 2:48 am |
| New house, need to wire for a network | July 23, 2005, 12:35 pm |
| OMNI PRO Network Connection | November 6, 2005, 3:21 pm |
| Tool kit for network wiring | July 20, 2006, 3:33 pm |
| Use of FTP cable in home network | September 29, 2007, 5:24 am |
| insteon, what goes on at the network level? | April 16, 2008, 12:40 pm |
| assistance checking network speeds | June 17, 2005, 10:09 pm |
| Keypadlinc interferes with homeplug network! | November 15, 2005, 1:59 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
