I have a bunch of X10 stuff installed and it is flaky.
Problem #1:
Some parts of the house can't be controlled from some equipment etc.
The below will solve the problem, correct?
Problem #2:
I have a series of the X10 Slimline switches which, since they don't plug in to anything, must actually be small RF remotes, correct? These switches are flaky, I'm guessing because the signal is inconsistent. Would the following help?
