I did this in VS6. The cpp is in the first part. The dsp follows to create cm17a executable.
#include #include #include
#define CODE_HEADER 0x55AB #define CODE_FOOTER 0xB5
#define CODE_A 0x6 #define CODE_B 0xE #define CODE_C 0x2 #define CODE_D 0xA #define CODE_E 0x1 #define CODE_F 0x9 #define CODE_G 0x5 #define CODE_H 0xD #define CODE_I 0x7 #define CODE_J 0xF #define CODE_K 0x3 #define CODE_L 0xB #define CODE_M 0x0 #define CODE_N 0x8 #define CODE_O 0x4 #define CODE_P 0xC
#define CODE_01 0x0000 #define CODE_02 0x0800 #define CODE_03 0x1000 #define CODE_04 0x1800 #define CODE_05 0x0200 #define CODE_06 0x0A00 #define CODE_07 0x1200 #define CODE_08 0x1A00 #define CODE_09 0x0020 #define CODE_10 0x0820 #define CODE_11 0x1020 #define CODE_12 0x1820 #define CODE_13 0x0220 #define CODE_14 0x0A20 #define CODE_15 0x1220 #define CODE_16 0x1A20
#define CODE_ON 0x0000 #define CODE_OFF 0x0400
#define CODE_BRIGHT 0x1100 #define CODE_DIM 0x1900
DCB dcb; HANDLE hCom;
void SendByte(BYTE bValue) { for (BYTE b = 0; b < 8; b++) { // wait dcb.fDtrControl = DTR_CONTROL_ENABLE; dcb.fRtsControl = RTS_CONTROL_ENABLE; Sleep(1); SetCommState(hCom, &dcb); if (bValue & (1 1)) { printf("Invalid command code\n"); return; } WORD commandCodeArray[] = {CODE_DIM,CODE_BRIGHT}; wCommand |= commandCodeArray[commandCode];
X10Command(wCommand); return; }
BYTE deviceCode = atoi(argv[3]); if ((deviceCode < 1) || (deviceCode > 16)) { printf("Invalid device code\n"); return; } WORD deviceCodeArray[] = {CODE_01,CODE_02,CODE_03,CODE_04,CODE_05,CODE_06,CODE_07,CODE_08,CODE_09,CODE_10,CODE_11,CODE_12,CODE_13,CODE_14,CODE_15,CODE_16}; wCommand |= deviceCodeArray[deviceCode - 1];
BYTE commandCode = atoi(argv[4]); if ((commandCode < 0) || (commandCode > 1)) { printf("Invalid command code\n"); return; } WORD commandCodeArray[] = {CODE_OFF,CODE_ON}; wCommand |= commandCodeArray[commandCode];
CloseHandle(hCom);
// X10Command(CODE_A | CODE_09 | CODE_ON); // X10Command(CODE_B | CODE_01 | CODE_ON); // X10Command(CODE_A | CODE_09 | CODE_OFF); // X10Command(CODE_B | CODE_01 | CODE_OFF); }
# Microsoft Developer Studio Project File - Name="cm17a" - Package Owner= # Microsoft Developer Studio Generated Build File, Format Version 6.00 # ** DO NOT EDIT **
# TARGTYPE "Win32 (x86) Console Application" 0x0103
CFG=cm17a - Win32 Debug !MESSAGE This is not a valid makefile. To build this project using NMAKE, !MESSAGE use the Export Makefile command and run !MESSAGE !MESSAGE NMAKE /f "cm17a.mak". !MESSAGE !MESSAGE You can specify a configuration when running NMAKE !MESSAGE by defining the macro CFG on the command line. For example: !MESSAGE !MESSAGE NMAKE /f "cm17a.mak" CFG="cm17a - Win32 Debug" !MESSAGE !MESSAGE Possible choices for configuration are: !MESSAGE !MESSAGE "cm17a - Win32 Release" (based on "Win32 (x86) Console Application") !MESSAGE "cm17a - Win32 Debug" (based on "Win32 (x86) Console Application") !MESSAGE
# Begin Project # PROP AllowPerConfigDependencies 0 # PROP Scc_ProjName "" # PROP Scc_LocalPath "" CPP=cl.exe RSC=rc.exe
!IF "$(CFG)" == "cm17a - Win32 Release"
# PROP BASE Use_MFC 0 # PROP BASE Use_Debug_Libraries 0 # PROP BASE Output_Dir "Release" # PROP BASE Intermediate_Dir "Release" # PROP BASE Target_Dir "" # PROP Use_MFC 0 # PROP Use_Debug_Libraries 0 # PROP Output_Dir "Release" # PROP Intermediate_Dir "Release" # PROP Ignore_Export_Lib 0 # PROP Target_Dir "" # ADD BASE CPP /nologo /W3 /GX /O2 /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /c # ADD CPP /nologo /W3 /GX /O2 /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /c # ADD BASE RSC /l 0x409 /d "NDEBUG" # ADD RSC /l 0x409 /d "NDEBUG" BSC32=bscmake.exe # ADD BASE BSC32 /nologo # ADD BSC32 /nologo LINK32=link.exe # ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /machine:I386 # ADD LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /machine:I386
!ELSEIF "$(CFG)" == "cm17a - Win32 Debug"
# PROP BASE Use_MFC 0 # PROP BASE Use_Debug_Libraries 1 # PROP BASE Output_Dir "Debug" # PROP BASE Intermediate_Dir "Debug" # PROP BASE Target_Dir "" # PROP Use_MFC 0 # PROP Use_Debug_Libraries 1 # PROP Output_Dir "Debug" # PROP Intermediate_Dir "Debug" # PROP Ignore_Export_Lib 0 # PROP Target_Dir "" # ADD BASE CPP /nologo /W3 /Gm /GX /ZI /Od /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /GZ /c # ADD CPP /nologo /W3 /Gm /GX /ZI /Od /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /GZ /c # ADD BASE RSC /l 0x409 /d "_DEBUG" # ADD RSC /l 0x409 /d "_DEBUG" BSC32=bscmake.exe # ADD BASE BSC32 /nologo # ADD BSC32 /nologo LINK32=link.exe # ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept # ADD LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept
!ENDIF
# Begin Target
# Name "cm17a - Win32 Release" # Name "cm17a - Win32 Debug" # Begin Group "Source Files"
# PROP Default_Filter "cpp;c;cxx;rc;def;r;odl;idl;hpj;bat" # Begin Source File
SOURCE=.\cm17a.cpp # End Source File # End Group # End Target # End Project
