General Home Automation wiring for the future
Subject Author Date
wiring for the future les.stockton@gmail.com 03-27-07
Posted by les.stockton@gmail.com on March 27, 2007, 7:54 pm
I'm building a house and would like to prewire, or at least provide
adequate conduit for running cable later with regards to routing audio
and video to most rooms in the house. HD will be a factor at some
point in time, but wiring for that now wont accomodate current
equipment.
So I'm wondering what is recommended as far as pre-wiring a house in
construction. Do I run one conduit with RG6 for current equipment (as
far as video), and then have an empty conduit for the future, and if
so, what size?
I know this doesn't even address audio, which I also plan on piping to
the rooms.
All of this will be homed to one room where I'll also have network
equipment and at least one server. I'll be running network to most
rooms too, but I'm pretty sure I know how to take care of that. I
just want to make sure that I cover audio/video needs (current and
future).
I'm also looking at matrix switches, although I know that up front,
because they're expensive, I probably can't afford one, but I'd like
to be able to use one later.
I'm planning on using some kind of structured cabling panel as well
and looking to hear what some other people are using and are happy
with.
Posted by Robert L Bass on March 27, 2007, 9:07 pm
> prewire, or at least provide adequate
> regards to routing audio and video to
> a factor at some point in time, but
> current equipment...
Actually, you can wire for HDTV but
use the same cables for standard
definition until you're ready to upgrade
your gear. The sameRG6 that the
cable and satellite companies use to
carry HDTV will do just as well carrying
regular channels.
You should also pull three "RCA" cables
for component video to distribute
media from common sources such as
a DVD player, PC, etc., to various
rooms. Any one of the component
cables will carry composite video
(standard TV) around the house so that
won't be wasted or redundant.
For audio distribution you need several
types of cables. CAT5 goes to each
room for remote control station (touch
screens, etc.). 14/2 or 14/4 goes to
a volume control at the same location
as the touchpad and grom there to
the speakers.
Those few cables are pretty much all
you'll need for current and future
technology. You could get fancy and
run fiberoptic cables but there's no
real nead for tham now or in the
near future.
> as far as pre-wiring a house in construction.
> equipment (as far as video), and then have
> so, what size?
Empty conduit is handy for runs that you
will be unable to access later. However, if
the home is wood frame and there's a
basement, you should be able to access
most places for retrofit if needed. Run
conduit where you know it will be a PITA
running cable later.
At most I would run cables through the
walls and run a single, 2" conduit as well.
If you have an attic or basement do run
at least two 3" conduits between them
and the wiring closet, wherever that will
be.
> which I also plan on piping to the rooms.
See comments above but the formula is
simple. This is what I instruct my DIY
customers to do. From the entertainment
rack or wherever your gear is, run video,
speaker level audio and CAT5 to a volume
control location in each room. At the
V/C location make an 18" loop of extra
video cable and continue the wire over
to wherever you might someday want to
put a TV set, projector or whatever.
Do the same thing with the speaker cable.
Make an 18" loop at the V/C and continue
across the ceiling and over to the planned
speaker locations.
Once again with the CAT5, make an 18"
service loop and continue over to one of
the speakers. It makes no difference if
it's the left or right speaker but be
consistent from room to room. CAT5
can be used for a remote station to run a
multi-zone system such as Russound,
an A-BUS type system or a simple IR
repeating system such as Xantech. The
CAT5 at the speaker can be connected
to an IR receiver hidden behind the grill.
This makes it easy to control your gear
with a remote, by touchpad or whatever
your heart desires and budget (or wife)
will permit.
> where I'll also have network equipment
> and at least one server...
Standard LAN cabling, CAT5e or CAT6,
will be fine for PC-based media distribution.
This is in addition to the cables already
described.
> I'll be running network to most rooms
> take care of that. I just want to make
> (current and future).
No problem. If you would like to discuss
this stuff at greater length, feel free to
give me a call. I'm usually around.
Regards,
Robert L Bass
Bass Home Electronics
941-925-8650
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Posted by les.stockton@gmail.com on March 28, 2007, 10:17 am
What type of wire should I run for the RCA lines? Do I run CAT5 or
something else?
Posted by Robert L Bass on March 28, 2007, 6:29 pm
> lines? Do I run CAT5 or something else?
No. Don't run video over CAT5 if you have the opportunity to run coax. While
it is possible to run it through UTP cable, you'd
need to add BALUNS at each end. That adds to the overall cost of the job with
no added benefit.
I use the expression "RCA cables" only because it is in common use.
Technically, they're just 75-Ohm shielded cables with RCA
connectors on the ends. Any decent 22-gauge, shielded cable will carry video or
audio hundreds of feet with no perceptible
degradation. I've even used 2-conductor shielded in a pinch and it worked fine
at over 300 feet.
Component video calls for the exact same thing -- 75-Ohm coaxial cable. Because
it is high definition, you should use only 75-Ohm
coax (rather than just any old shielded stuff).
Do NOT believe any of the hype from Monster or any of the other cable rip-offs.
As long as it has a good shield and the connections
are secure, there is zero difference between cable that costs $0.20 a foot and
that which costs $50+ / foot.
Regards,
Robert L Bass
941-925-8650
Posted by Reg on March 28, 2007, 1:53 pm
Aren't these very susceptible to noise? What would be the maximum
run length that you'd recommend?
Reg
Similar ThreadsPosted
wiring for the future March 27, 2007, 7:54 pm
XTB - the Future of X10 has arrived! May 28, 2006, 9:58 pm
Prewiring for future lighting automation October 7, 2005, 11:58 am
cartoon: Visions of a High-Tech Future May 10, 2005, 11:50 am
Newbie: Wiring for HA April 10, 2005, 1:06 pm
Help with OnQ telcom wiring May 1, 2005, 7:19 pm
Home Wiring How To September 13, 2005, 5:49 pm
Network Wiring: A or B? January 31, 2006, 6:44 pm
Microphone wiring February 25, 2007, 6:41 pm
DSL wiring question March 18, 2007, 12:40 am
Structured Wiring Questions March 11, 2005, 7:21 pm
16 AWG Wire from Structured wiring May 1, 2005, 9:56 pm
Low voltage wiring - NEC question September 3, 2005, 11:45 am
CCTV Modulation Wiring September 14, 2005, 9:38 am
Structured Wiring Hub Layout September 28, 2005, 6:46 am
