I'm still a bit new to the home automation space and I'm having trouble figuring out the best way to handle remote IR. I have my a/v equipment in a cabinet so I need to get IR signals into the cabinet. I plan to do this with a Russound 857 and a wired IR receiver. However, I also want to send IR signals from other rooms that I won't be able to run wires to. Currently, I'm using Powermids. Can I use the Powermid with the 857? Of course, I could simply use the Powermid with an IR emitter in front of the wired IR receiver, but I was wondering if I could plug the Powermid receiver directly into the 857? If not, is there another wireless solution I should consider?
TIA.
- Leon
