Anybody know if it's possible to get some small wireless devices (Bluetooth or WiFi) that you eg. put in different outlets in your house and thereby be able to turn the power on or off from your computer?
It could also be temperature measuring devices, something that can push a button, turn something around, register sound, light, or movement, or whatever - just simple small wireless to do some very simple tasks and then be able to command them programmatically from the computer they are connected to.
I would like to avoid a complex and expensive system like I would think X10 would be, just some small devices that you simply connect to the computer...
Allan
