Hello gang!
I received advice from an engineer today.
He suggested I use a bunch of separate amplifiers instead of one larger one.
This way I can set the level in each room.
I want to run them off of 12 volts DC.
"No problem", he said... "Use car amps!"
I want small size. Pack of cigarettes?
They can be stereo, or mono at this point.
I want to put them into a structured wiring box, or hang 'em on the wall.
Low wattage. (Real watts RMS) I could probably make due with 10-watts per channel.
Elk Products makes their Elk-800 10-watt Audio Amplifier. This is almost ideal...
Anybody know where I can get a bargain, as I'm gonna buy a few of these...?
And I prefer the car amp idea as they are often all metal chassis that I can possible blow across with a fan for cooling.
Anybody seen any surplus audio amps?
Thanks!
Jack :)
