W800RF32 and DS10A
I wish to use several DS10A units with a W800RF32. If the DS10A units
generate their own codes [not set by code wheels] then I assume the
W800RF32 simply receives and passes these code on to the computer and
at this point software must interpret the code[s]. Does a extensive if-
then table of every code combination have to be set up in the software
to archive automation based on the code[s] received?  Secondly, if you
change the DS10A batteries does the unit generates another random code
for itself?        TIA.... Mug
Site Timeline
