TW523 no longer transmitting. Repairable? Any compatibility with CM11A?
Threaded View
I have a homebrew home control system that interfaces with a TW523 to the
powerline for signals. Commands are sent to it using X10 controllers and it
sends commands to devices (but not anymore).
I have an HD11A, which I believe is the same as the CM11A. I don't expect it to
work, but wonder if there is any chance that it can "emulate" a TW523.
Or, has anyone every repaired a TW523 failure to send X10 signals over the
powerline. The failing unit's LED still flashes as the signals are sent, but no
signals are received by the devices it is trying to control. Advise as to how to
repair this could save me some time.
The Tw523 still receives X10 signals fine, and properly relays them on to the
processor in the control system.
Re: TW523 no longer transmitting. Repairable? Any compatibility with CM11A?
A quick Google for 'tw523 two-way x10 controller' found over 15K results
http://www.x10.com/products/x10_tw523.htm indicated they are still
available for $29.99 (US)
Rich W.
Bob F wrote:
If the LED flashes, odds are it is still sending but some new device is
attenuating or interfering with the signal.
Try moving it to another location. If it starts working, try to find the device
that's causing problems.
The HD11A will not emulate the TW523. It uses RS232 and has a totally different
interface.
I have one which seemed to similarly stop working. It could still receive.
I moved it so it connects to the supply right near the consumer unit
(panel), and it seems to be working again OK. Don't know if it was due
reduction in transmit power, or if some new appliance is attenuating it
much more than it used to, but it now has a shorter mains signalling
path to most of the X10 switches. The TTL signal connection to the device
is now some 15m (50') over a chunky screened cable (used to be an RS232
VDU connection cable), but still seems to work OK.
Andrew Gabriel
[email address is not usable -- followup in the newsgroup]
   Maybe a small memory leak eventually robbed the device of all
available working memory. I've had IP cameras like that which had to be
reset every few weeks just because of that. But then a later firmware
update fixed it.
I have had memory leaks that completely ruined my CPU!  Bits got out, jammed
up the fan bearings, and then eventually shorted out a few of the data lines
causing it to overheat, simultaneously shutting down the cooling algorithm.
The thing went up on fire and spread to the whole block. My insurance
wouldn't cover the damages and now I post from prison. I don't touch mega
anything,  anymore. It's all 1KB at a time for me. The glass containers for
the memory chips are helping somewhat.
update fixed it.
Site Timeline
