Does anyone know if you can stop a macro on the 1132CU? I presently start a macro when a detector senses dusk. Then, over the next hour lights are turned on. However, a passing thunderstorm sometimes starts the macro and in a few minutes, it might get bright again. I do, then turn off all the lights from another macro, however, the first macro continues to run and, depending on timing, turn on one or more lights. I know I could put in another step to turn off the lights at x+50 minutes, but a "stop macro" would be great. Any ideas?
- posted
18 years ago
