| > | I recently added a SignaLinc Repeater 3-Wire Dryer which has | > greatly | > | improved X10 reliability in my home. But, none of the dims that I | > have | > | programmed in Active Home Pro ever activate. For example, a simple | > C1 | > | dim to 50% (or any other %) just turns the lamp on. Before adding | > the | > | bridge/repeater the dims would perform properly. Note that I also | > | tried setting the AH to repeat the command, no help. | >
| > (previously you wrote:) | >
| > |After 15yrs of X10 signal problems, and adding numerous different | > |boosters, couplers and repeaters (none of which helped), my | > problems | > |have been solved with a SignaLinc Repeater 3-Wire Dryer | > |amplifier/coupler/repeater
... | > |FINALLY! :D | >
| > Well, that was a short honeymoon. :) | >
| > Which repeaters had you tried before the SignalLinc? In particular, | > did you try any of ACT's offerings? | | Hi Dan, I have been working too much (60-80hr weeks, ugh) to respond | to your other question, I wasn't intentionally ignoring you (well, | actually I was :) ... anyway, no I don't think I tried any ACT | products. I must say though that even though the dims are not coming | through when sent with AH via my PC otherwise having high reliability | of at least on/off is tremendous. Note that I can dim using any of | the remotes, it's just AH that won't dim, very odd, but I'm no X10 | guru (but definitely a veteran, one of my 1st X10 systems was based | around an X10 board (with ultrasonic sender, i think) in an Apple II | circa 1980, ha).
The *Linc products have a history of (shall we say) disagreements with Active Home over the correct interpretation of the X10 protocol. I see no reason that this has not extended to Active Home Pro. Unfortunately, while the last area of disagreement was fairly easy to understand I don't see off hand how they could argue about DIM/BRI sequences since pretty much everybody agrees that they are sent back-to-back. On the other hand, they are really creative with their screw-ups...
As always, I would recommend trying an ACT repeater. They seem to have the functionality down, though there are (were?) some construction issues. If you like you can try my spare/repaired CR230.
Dan Lanciani ddl@danlan.*com
