General Home Automation seeking smart folder solutions
Subject Author Date
seeking smart folder solutions Stefaan Meeuws 05-20-06
Posted by Stefaan Meeuws on May 20, 2006, 5:07 pm
I tend to create a folder structure on the PC's that are networket @
home. Then, I like to use a SyncToy to manage the contents.
Here's a question: I want to use/write/steal some software that will
_generate_ a number of different folder structures, grading them with a
quotation.
This is what I'm after:
root1 --- dev --- doc --- html ---- proja
+ + +-- projb
+ +- msword -- proja
+ +- projb
+ +- excel --- proja
+ +- projb
+- src +-- vb ------ proja
+ +-- projb
+- vc++ ---- proja
+ +-- projb
+- java ---- proja
+-- projb
root2 --- doc --- proja --- src
+ +--- vb
+ +--- vc++
+ +--- java
+ +-- doc
+ +-- html
+ +-- msword
+ +-- excel
+- projb --- src
+--- vb
+--- vc++
+--- java
+-- doc
+-- html
+-- msword
+-- excel
Rather than actually create the folders, and populating them using a
_pool_of_files_ I think I need a __view__ object that discreetly hides
the technical layout of the file system.
What can I use to make headway into the design of the UI of these
"view_folders"? Spare me the wild 3d stuff for now.
One practical use of such _view_folders_ would be something I now create
by hand:
winxp --- settings --- Computer Mgt --- Svc and Apps --- Svcs
+- Dvc Mgr -------- PC1 --- Comp
+- Disk Dr
+- Disp Ad
+..... etc
here, leaf folder Svcs contains several files (with naming convention):
[mm-dd-yyy hhmm abbrev] . [htm]
                                                [mm-dd-yyy hhmm abbrev] . [mht]
                                                [mm-dd-yyy hhmm ] . [txt]
[mm-dd-yyy hhmm abbrev] . [xml]
                                                [mm-dd-yyy hhmm ] . [xml]
leaf folders Comp, Disk Dr, Disp Ad, etc.. don't contain anything yet.
It's clear that mapping this MS Management Console output will be a
_real_ pain in the neck for me. If I had the courage to move ahead with
it. I tend to fill the folder structure on a need-to-know basis.
Your thoughts much appreciated!
stefaan dot meeuws at gmail dot com
[05-20-2006 2300]
Similar ThreadsPosted
seeking smart folder solutions May 20, 2006, 5:07 pm
seeking intelligent folder structure May 20, 2006, 5:23 pm
newbie looking for cheap solutions April 26, 2005, 1:42 am
Get Smart......www.AutomationMedia.com March 8, 2006, 11:27 pm
Smart Home Automation July 2, 2008, 2:09 am
PCS X10 Smart Switches Scenemaster V3.0 New for Sale February 7, 2005, 9:58 pm
Smart Mortgage Refinance website opens March 14, 2006, 9:48 pm
Smart window blinds. Help needed to start. June 5, 2008, 6:58 am
Smart Home Show 2007 - Videos and Review March 27, 2007, 5:10 am
