=== Burglar bars square tubing assembly ===
=== Car jack === Criminals use a car jack between the window frame and first iron rod to jack the rod out of the frame.
=== Broad Square tubing on inside === Fit broad 10cm square tubing on inside of the wall next to the window frame and secure by drilling through the wall with a handy bar. The broad square tube is 10cm in width and 5cm in height. On the outside the handy bar is secured against a base plate and welded to the wall. Weld Y12 concrete rods to the broad square tubing on the inside of the home.
This whole square tubing, Y12 rod assembly is monitored by a vibration sensor [[ConfiguringAlarmSystem]] , strain gauge or resistance measuring circuit.
Using a cutting torch or car jack will change the resistance of the assembly. Monitor the resistance with a constant voltage, A/D converter and [[AtmelMicro]]. Increasing the temperature of the assembly will increase resistance changing the voltage. Forcing the bars open with a car jack will also change the resistance altering the voltage measured by the A/D converter and triggering an alarm. Manually cutting any of the bars will generate a vibration measured by a GE vibration sensor. The sensors should be placed inside the square tubing during assembly of the Y12 structure. Sensor that are exposed can be manually tampered with , by enclosing it the vibration sensor will pick any attempt at getting to it.
