roZetta will understand the protocols for...
TW523/PL513 CM11A 2414S UPB PIM CPU-XA/Ocelot/Leopard MR26A
roZetta will emulate a TW523 for any controller (e.g. Ocelot, JDS Stargate, HomeVision, Omni) that expects a TW523 attached to its PLC port and can output PLC codes using any of the above listed devices (MR26A excepted). I've designed a generic DIY project board that fits a standard Polycase LP11(F) 2.5x2.5x1" enclosure that can be used to build RF receiver modules for anything using ASK modulation and either 310, 315, 418, or 433.92MHz (for which Mouser sells $5 receiver modules). I will create firmware for an
8-pin PIC to decode the RF and output the codes via RS232. These will have to be "home-built" although I'm willing to discuss supplying them assembled for anyone willing to pay for FCC testing ($5K and up).I've already committed to try to support the Oregon Scientific (and Radio Shack) wireless weather transmitters. (Actually, roZetta might also interface with their serial devices.)
I know the protocol for Crestron RF but wonder whether it's worthwhile to support it since they appear to be moving to Zigbee. I also understand Lutron's RadioRA protocol but am not sure it lends itself to this application - their codes are ridiculously long which would require extra memory in any receiver.
I'm willing to entertain suggestions but will not actually start working on any suggestions until after I've released the first version of the firmware.
roZetta will be field upgradable so the fact that early firmware will not support these other devices is not an issue.
Some of the wireless protocols will not require much in the way of roZetta resources. The RF receiver will output a hex string and the user can specify a response. roZetta will not need to "understand" the underlying protocol and no handshaking is needed so roZetta will be able to support lots of these device types.
Others (e.g. Oregon Scientific weather devices) will be inputting variable data and roZetta will need some level of "understanding" to deal with the data. I might be able to generalize the approach I took with variable sensors in the BX24-AHT but these types of devices will always require more resources so only those with wide appeal and for which the protocol is available will be supported.
