Retrofitting Motion Sensor?
Threaded View
I have a few two-bulb floodlights mounted in the usual boxes.
Bought a retrofit motion sensor with the thought of converting
one of the boxes to motion sensing.
Physically, no problem: the sensor screws right in to one of the
threaded holes already in the box.
But I'm guessing I still need some sort of relay so the motion
sensor trips the relay and the relay applies the AC to the bulbs.
Googling didn't reveal anything.
Anybody been here?
Pete Cresswell
Re: Retrofitting Motion Sensor?
On 8/20/2012 1:20 PM, (PeteCresswell) wrote:
The answer is some will probably drive the lights directly and some won't.
Some will drive CFLs and some won't.
Need far more info about the "retrofit motion sensor".
Per Art Todesco:
Heath/Zenith SL-5316-BZ-C as in http://tinyurl.com/cng5qnw
I don't think it drives the lights because the black and white
wires are so thin.
Pete Cresswell
I'm currently using several of these units.  They're capable of directly
driving a lighting load of 500W  (4.2A), max.
See the data sheet at:
http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Google is your friend.. just search for Zenith SL-5316.
--buzz
Per kf:
Bingo!
Working like a charm.
Thanks.
FWIW, the PDF in the link's wiring diagram was different from the
diagram that came with the unit - and, of course, the PDF's
diagram worked.
Either I misinterpreted the one that came with the unit or it
just did not work.
Pete Cresswell
Site Timeline
