General Home Automation remote control for my computer
Subject Author Date
remote control for my computer dmehling 08-13-07
Posted by on August 13, 2007, 5:48 pm
I have been trying to figure out ways of remotely initializing macros
on my computer. There are remotes that are made for that purpose but
they are too bulky and have far more buttons than I need. I need a
very compact remote with no more than 10 programmable buttons. At
this point I will probably need to use either WinLIRC or Girder to
interface with the type of remote I am needing. Which of these two
programs would be better and would they be compatible with this remote
and IR receiver:
http://www.x10.com/automation/kr22a_s.html
http://www.x10.com/products/x10_mr26a.htm
Posted by Dave Houston on August 13, 2007, 7:56 pm
>and IR receiver:
Both of those are RF not IR but Girder should be able to handle the MR26A
serial output.
Posted by on August 14, 2007, 8:11 pm
> >and IR receiver:
> serial output.
If both of those devices are RF does that mean they are probably
compatible with each other? Also, how complicated are the codes or
whatever you want to call it that are transmitted by RF? I would
like to write a program in Visual Basic that could take the input from
the serial port to execute different macros.
Posted by Dave Houston on August 14, 2007, 10:11 pm
>> >and IR receiver:
>> serial output.
Yes, they are compatible.
The MR26A outputs a 2 byte header, 2 data bytes and a 1 byte footer. The
details are given here...
http://software.x10.com/pub/manuals/cm17a_protocol.txt
In hexadecimal, it's always <d5><aa><data><data><ad>.
Posted by Dave Houston on August 15, 2007, 6:29 am
>and IR receiver:
One thing I missed was that you want "programmable" buttons on the remote.
The KR22A allows you to assign an X-10 address (from a set of 256) to the
first set of buttons. The next 3 sets automatically follow in sequence and
the last set (Dim/Bright) send codes that depend on which address was
assined to the first pair. While I suspect it will do what you want, the
button "progammability" is extremely limited.
ftp://ftp.x10.com/pub/manuals/kr22a-is.pdf
Similar ThreadsPosted
remote control for my computer August 13, 2007, 5:48 pm
FS: JP1 cable to program your universial remote control, now youcan control anything you want! July 14, 2005, 10:46 pm
x10 control from computer November 19, 2005, 11:52 am
Computer control of an audio multiplexor December 2, 2007, 3:14 pm
Computer Control over Leviton Green Series Components August 4, 2007, 7:56 am
Remote control November 26, 2005, 12:40 pm
IR remote control to RF February 18, 2006, 5:13 pm
PC remote control of Tv August 19, 2007, 3:26 pm
Remote Monitoring and Control August 16, 2005, 10:35 pm
PDA control via Universal Remote August 29, 2005, 6:34 am
MUX serial remote control December 8, 2005, 8:09 am
remote control over internet January 19, 2006, 11:04 am
remote control for HAI Omni July 21, 2006, 12:11 am
RS232 remote control July 21, 2006, 12:16 am
Control my PC with a remote control via a USB IR ? October 18, 2006, 2:23 pm
