Neither will do what you want at this time. You need to know the protocol and there are just too many proprietary protocols to try to tackle reverse engineering all of them.
These are popular enough that it might be worthwhile to look into them but I don't have time right now. A lot are made by the same company but just have different brand names so if you get a protocol for one you have it for all. I think this may be one that uses the protocol for which Don Lancaster published details.
I've designed a DIY generic module that can be used to build RF receiver modules. It would just require the right receiver board (i.e. frequency) and a PIC that was designed to decode this specific protocol. I'll look into it after I get roZetta released.
What I'll try to do is program a PIC to output the pertinent data in human readable form so that roZetta doesn't need to know the details. If you have the receiver on port P2, you'll see something like "HH:MM:SS P2 ID 76°F" where ID identifies a specific sensor and you can program whatever action you wish as a response. It this way it could also be used with the ZX24-AHT once I port that code to the ZX-24 chip.
You can buy a $5 RF receiver from Mouser and c>I have a number of Wireless temperature sensors around the house. >
