General Home Automation reading in data from rs232 port, require to resend as an email
Subject Author Date
reading in data from rs232 port, require to resend as an email Lyn 04-02-08
Posted by Lyn on April 2, 2008, 7:20 am
I am reading in some temperature sensor data, via RS232 (actually
converted to USB via a CP2102 ), approx every hour into a Windows XP
PC. It reads fine into Windows Hyperterminal. I want to be able to
send this data out via email as it comes it. Is there any application
that can do this, free or commerical, please? I have searched using
Google but not found anything.
Lyndsay Williams
www.girtonlabs.com
Posted by Homer L. Hazel on April 2, 2008, 10:00 am
There is an application called BLAT which allows you to send email
via a command line interface. I believe it is freeware.
You can find it with Google.
Larry Hazel
> Lyndsay Williams
> www.girtonlabs.com
Posted by rlsusenet@NOSPAMPUHLEEZschnapp on April 2, 2008, 6:15 pm
> Larry Hazel
>> Lyndsay Williams
>> www.girtonlabs.com
Alternatively, it ought to be relatively easy, using Perl, to read the
data over RS232 via the Win32::SerialPort package, and send it over
email via the Net::SMTP package. You wouldn't use Hyperterminal at all.
If Hyperterminal has macro capability with iteration and time awareness,
and can save the recorded data and fire off a command line program, then
Larry's suggestion might indeed be the simplest.
I'd do it in Perl.
Posted by Si Ballenger on April 5, 2008, 1:52 pm
>Lyndsay Williams
>www.girtonlabs.com
I made the below setup use a vbscript to send email from a simple
programming language called just basic. You can run the vbscript
with arguments using a batch file.
http://justbasic.conforums.com/index.cgi?board=shared&action=display&num=1184377182
Similar ThreadsPosted
reading in data from rs232 port, require to resend as an email April 2, 2008, 7:20 am
Supply 24 Port Patch Panels,24 Patch Panels,24 Port UTP Patch Panels,24 Port Cat5e Patch Panels,RJ45 Patch Panels,Modular Patch Panels April 1, 2006, 3:25 am
Reading Wireless Temp February 3, 2006, 2:12 pm
Reading water meter? August 15, 2006, 9:41 pm
Reading power levels December 1, 2006, 3:39 pm
RS485 OR RS232 to X10 June 4, 2007, 3:35 am
Re: usb data collecting? November 17, 2007, 6:47 pm
Re: usb data collecting? November 17, 2007, 6:58 pm
usb data collecting? November 17, 2007, 10:13 am
RS232 remote control July 21, 2006, 12:16 am
Samsung LCD (403T) RS232 codes February 22, 2005, 4:27 am
power metering data aquisition in Australia April 26, 2005, 3:04 pm
Where can I find RJ-11 to RS232 Cable for my Powerline Interface? October 22, 2005, 7:35 pm
Surge protection for 4-20mA sensors and data logger? April 10, 2007, 7:53 am
Surge protection for 4-20mA sensors and data logger? April 11, 2007, 5:28 am
