Does anyone know how these things work? Smarthome has discontinued the
2382W but I have some 1135W switches I am trying to get to work with some 23885W relay switches.I am trying to replace two manual 3-way switches controlling a couple of floodlights in a hall. I am using the relay switch because I have replaced the bulbs with flourescents. I am able to control the load properly with the 23885W but have been unsuccessful in getting the 1135W working with it. The manual for the 2384W
As I said, the relay switch is controlling the load fine by itself, but I need a switch at the other end of the hall as well. I have tried two different 1135W companion switches and neither one will operate the load via the 23885W. The black wire of the 1135W is connected is to 120V, grey (there is no white wire) to neutral, and yellow is connected via a runner back to the yellow wire on the 23885W. Here is what I am seeing.
1) The nightlight LED (at the top of the switch) does not light on the 1135W, whether or not the yellow wire is connected. Is this right, or should this LED be lit whenever power is connected?2) What kind of signal is sent out via the yellow wire? Is it a DC level or a pulse, or something else completely different. What should I look for?
3) Is there something I can do to the yellow wire of the 23885W to make sure that the companion switch connection to it is operational?Any other troubleshooting tips would be greatly appreciated. TIA.
