I need to monitor IG pool water temperature. I have an OmniPro II and HAI 14A00-8 Water Temperture sensor. Any idea exactly how to get temperature measurement into the water flow. I was thinking a thermowell installed in return PVC but I'm not sure which type of Thermowell or exactly how to install. I'm concerned drilling a hole in PVC for temperature sensor will cause leakage under pressure. Are there any simpler methods, short of wrapping sensor outside of pipe with insulation? Any other ideas? Thanks !
- posted
17 years ago
