Hi
Hopefully I am posting this to the correct forum. I am a UK resident and would like a solution for the following:
I have a PC acting as the centre for my Home Theatre - As a little touch I would like a cheap option to add to the PC so as to control the lighting in the Home Theatre.
Lighting is currently controlled from a 240v wall switch which controls 3 separate lights in the room. I also would like to control a small table lamp which plugs into a conventional wall plug socket.
Thanks in advance
Piers (UK)
