Does anyone know where I can purchase an outdoor type enclosure for a Veo wireless camera? Mounting it inside a window isn't getting the job done for me.
Thanks!
Thanks!
Not being familiar with your particular product, I haven't a clue as to where I should direct you. It would also help if you told us where you lived and what kind of temperatures you experience in the winter and summer months. This will determine if you need a heater and/or blower. What voltage does the camera work at?? Where are you going to be mounting it?? Will you need a IR cut fither? Sun shade? Vandal resistant housing? Sure I could point you at a dozen housings from Pelco
