Now with pictures!
Subject
- Posted on
Open and Closr my Gate over the internet.
- 07-03-2008
July 3, 2008, 11:05 am
I have a gate at the front of my driveway and at least once a month I
have to leave it open for the power company so they can read my
meter. I recently got my camera system conntect to the internet so I
can watch my house from work. It is a novilty now I know. Well I
just saw the power company leave and thought how cool it would be if I
could now close the gate. The gate opens and closes with a standard
garage door opener. What would be the best way to do this?
Thanks,
Rodger
Thanks,
Rodger
Re: Open and Closr my Gate over the internet.
You could use a servo to push the buttons on the remote. I use
servos for pan/tilt cams over the web. The first link below uses
javascript to send a position command when the button is pushed,
and send another position when the button is released. If you can
see the gate with your cam, then you could push the closed button
on the remote untol the gate is closed, then release the button.
The bottom link has another pan/tilt cam setup.
http://www.geocities.com/zoomkat/mousebutton-T.htm
http://www.geocities.com/zoomkat/ezservo1.htm
then you could close the gate by having a device trigger an opener's
button. You don't mention what, if any, home controller you have so,
assuming you have none, you could use a simple timer set to close the
gate after the usual time he reads the meter. Another method would be to
use a motion detector by the meter. When motion is detected, there is a
5 minute delay using an inexpensive 555 timer circuit and then it
closes.
Agreed on both points.
Also note: If your system has a single button to open / close the gate and
you decide to automate (timer, sensor, etc.) the operation, you'll need a
position sensor to prevent the gate from opening after a raccoon or deer trips
the motion detector. I did something similar for clients who had the habit of
forgetting to close the garage door. Sensors prevented closing the door on an
object or a person. Another sensor detected door position. I used changes in
state of the alarm system from disarmed to armed or vice versa to start a
count-down timer. Upon time-out, if the door was still open and no
obstruction was present it would close. It worked.
If your meter reader drives rather than walk through the open gate a direction
sensitive vehicle detector can be used to close the gate as soon as his
vehicle exits. Note, however, that unless you add other stuff (an automation
or security controller for example) to the mix the system will close the gate
after anyone goes out. This may or may not be a good thing, depending on
whether you like to leave the gate open when you're at home.
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-870-2310
Fax 941-870-3252
You haven't mentioned what (if any) home alarm equipment you have. My
partner has a similar setup at his house. He leaves the gate open in
the morning twice a week so that the maid service can freely enter, do
their job, and leave. He has an Ademco Vista 128FB and uses the
telephone line interface to dial up the system to close the gate and arm
the outputs on the DVR. If your gate system utilizes a wireless remote,
it would be fairly simple to bypass the button on the remote and wire
the contacts directly to a relay that you can control remotely.
SG19LD804-161. That is all they really have in the way of home
automation, I'm not sure I would even consider that as automation.
They figure I would be better to explain and understand what they have
and want.
I have just started looking into all this stuff myself.
The gate opens with a simple garage door type remote. If I did run a
wire to the relay then how would I connect that to my PC or some other
system so I could open and close it over the internet.
The only thing I have really seen is x10 stuff. I did purchase a
camera set from them about 4 years ago and was so disappointed in how
much you had to setup to get it to record to a VCR. I did purchase
the USB connector so I could get it on my PC, but could never get that
to work. So needless to say I do not have a lot of confidence in
them. I know the system was not all the much so I really got what I
paid for. I recently got the Dlink DCS-5220 IP Camera for my house
and am impressed at how clear the picture is and I like the PTZ
feature. Plus it connectes to my PC so it does all the recording and
getting it to work over the internet was a snap.
Any help is greatly appreciated. What are some good website were I
can read up on all this stuff and see what are some of my other
options.
Then next think I am going to look at is wireless alarm systems, but I
want connectors that are not these huge bricks like x10 has.
Thanks again,
Rodger
X10 generally is crap. But their video is not the same technology as their
RF remotes and powerline devices. About the only thing from X10 that
doesn't completely suck is their RF remotes. The video senders are garbage
as are the powerline devices. But at least the powerline devices can be
made to 'suck less' using 3rd party devices. Your simplest solution might
be to start with a powerline X10 relay control and one of the many PC-to-X10
interfaces.
-Bill Kearney
What relay from X10, or are you talking about their lamp modules door
modules? I am new at this . . .LOL.
Is there some software that you would recommend? Is there a Wireless
Alarm system you would recommend?
X10 had an alarm system for $100 and includes 11 door relays. I was
looking at some other companies and for the same amount of coverage it
was over $700, but they support x10 up to 8 devices. Would the x10 be
worth getting or just pay a little more and get something that is
nicer?
Thanks Again,
Rodger
Site Timeline
- » TW523 no longer transmitting. Repairable? Any compatibility with CM11A?
- — Next thread in » General Home Automation
- » Is ControlThink still in business?
- — Previous thread in » General Home Automation
- » Redraw wires
- — Newest thread in » General Home Automation
- » Verizon Direct Marketing [telecom]
- — The site's Newest Thread. Posted in » General Telecommunications Forum
- » Immediate Position:::Business Analyst With BI EXP::::At Housto...
- — The site's Last Updated Thread. Posted in » Nortel Networks
