OMNI PRO Network Connection
I'm having a fit trying to connect my Omni Pro II controller to my home network.
I have the basics hooked up because I can PING the controller successfully.
BUT.. I cannot enter an "encryption password" that works.
I am using PC Access (v 2.9).
When I go to the Configure - Network - Encryption tab, the dialog instantly says "bad password" for every password I enter.
Does anyone know the proper syntax for entering the 16 digit "password" into PC Access ?
curt
sealg
On 6 Nov 2005 12:21:27 -0800, snipped-for-privacy@direcway.com wrote (with possible editing):
First of all, you should be using PC Access v2.9c or later. Second of all, the password doesn't have to be 16 characters, but as I recall, it may be case-specific. Mine, for example, is only 8 characters. Third of all, you must be using the correct IP address and port number (4369) - I think you can set those without a password, the password is only required for encryption. I don't remember where that came from, but it is two parts and each part takes the form:
XX-XX-XX-XX-XX-XX-XX-XX
where "XX" are two hexadecimal upper case characters, like "6A" or "34".
L. M. Rappaport
Like Leviton SnapLink Mobile App, NQLink work with Leviton Security&Automat ion Omni/Lumina familly Controller. NQLink use latest technology for connec tion and data processing, NQLink much faster on connect than other app that you ever seen.
NQLink Provide both connection Local IP and Outside IP or domain name with one account for all devices: Controller, Hi-Fi2, Music Sever, Camera. App a utomatically looking for available connection every time. if you switch you r phone between Local wifi to cellular data network, NQLink automatically s witch connection also.
NQLink can run in background and start with your phone reboot to give you o ption notification on system such as: Security Mode, Lighting changed state .,etc.
NQLink Supported widget for function, GEO Fencing based on GPS Technology, Camera JPEG, MJPEG and RTSP H264/H265 format.
Feature:
  • Two option for display: List display and Grid Display (Touchscreen displa y mode)
  • Two connections Local IP and Domain name (Outside IP) supported
  • Looking for available connection automatically
  • Notification option for report system event
  • GPS GEO Fencing function
  • Voice control supported (Require Internet connection)
  • Supported HAI Music Gateway and Music Server
  • Supported Hi-Fi2 Equalizer Setting
  • Control light and Appliance.
  • Security management.
  • Air Conditioner Management
  • Multi Room Hi-Fi2 Audio system.
  • Macro Button Control
  • User Setting
  • Access Control
  • Room and Area manage by Users
  • Camera JPEG, MJPEG and RTSP H264/H265 format.
  • Press and hold Item desire to Re-name (Please enable Display as list in A ccount setting)
Comercial version:
ller
Thomas A.
