You'll need to wire them in series, no parallel.
- Vote on answer
- posted
18 years ago
Hooked up 3 windows to the same Zone. To get an NOT READY ALL 3 Windows have to be breached. How can I make it so that if only ONE is breached it would show NOT READY? I wired all 3 together and then onto the single wire running to the OMNI Pro II board.
On 29 Oct 2005 22:23:38 -0700, snipped-for-privacy@msn.com wrote (with possible editing):
Right, but you might also mention to the OP that the switches need to be NC (normally closed) NOT parallel NO (normally open) switches.
Thanks. It did the trick.
::: You'll need to wire them in series, no parallel.
Like Leviton SnapLink Mobile App, NQLink work with Leviton Security&Automat ion Omni/Lumina familly Controller. NQLink use latest technology for connec tion and data processing, NQLink much faster on connect than other app that you ever seen.
NQLink Provide both connection Local IP and Outside IP or domain name with one account for all devices: Controller, Hi-Fi2, Music Sever, Camera. App a utomatically looking for available connection every time. if you switch you r phone between Local wifi to cellular data network, NQLink automatically s witch connection also.
NQLink can run in background and start with your phone reboot to give you o ption notification on system such as: Security Mode, Lighting changed state .,etc.
NQLink Supported widget for function, GEO Fencing based on GPS Technology, Camera JPEG, MJPEG and RTSP H264/H265 format.
Feature:
Comercial version:
