The non responsive units are all the plug in modules - irrespective of where they are in the house. Yes the computer module triggers the plug in modules every time.
Hello, Dave! You wrote on Thu, 18 Aug 2005 10:53:35 GMT:
DH> Are the non-responsive units all on one circuit or on both?
DH> Do you have any way to send X-10 ??>> Hello, Dave! ??>>
??>> Single phase. Two power circuits - ie two fuses at the box. ??>>
??>> You wrote on Wed, 17 Aug 2005 10:16:08 GMT: ??>>
DH>>> Do you have single or multi-phase power? ??>>
DH>>> "Gargamil" wrote: ??>>
??>>>> Hello, All! ??>>>>
??>>>> After much stuffing around I finally got my Ocelot programmed and ??>>>> happening. One problem, whilst the Ocelot sees incoming X10, the ??>>>> X10 it sends is not picked up by any of the plug in units. All the ??>>>> hard wired units work fine. Any clues. ??>>>>
??>>>> I've even gone so far as to plug the XM10 into the same power ??>>>> point as a lamp. Nothing. Can turn it on and off with X10. The ??>>>> Ocelot sees those signals but sending X10 to the plug in modules ??>>>> result in 0. ??>>>>
??>>>> g ??>>>>
??>> With best regards, Gargamil. E-mail: snipped-for-privacy@tpgi.com.au ??>>
