Newbie veteran question
Hi there
I have be using X10 for over 25 years, but until recently never discovered all the on line info available for repairs, trouble shooting and modifications.
here is the question, I have a wall receptacle the ratchets when turned off, but operates fine when turned on. In the past I would toss it out and buy a new one, but now that I have found all of you.........repair or replace? if repair, suggestions / link please.
Thanks
Vette Guy
It's still easier to replace rather than try to repair. The Wall Rec. are notorious for their problem of a cheap plastic piece breaking. You'd think after all these years they'd have replaced it with a stronger piece but they haven't.
BruceR
Yep, for $10 to replace it, it's not worth trying to repair it.
Martin
AutomatedOutlet.com
