General Home Automation newbie X10 Freewire Question
Subject Author Date
newbie X10 Freewire Question Finlay Spicer 05-31-08
Posted by Finlay Spicer on May 31, 2008, 8:12 am
This may have once been asked and answered but a google search yielded
little. I have an X10 remote system :appliance modules, light
switches, transceiver, palm pad and those stick on RF switches that look
exactly like an electrical wall plate, and they all work well.
I needed a weatherproof controller and bought a Black and decker
freewire setup with a remote, a messenger hub 2 outdoor modules etc,
because I had read that they were X10 compatible. I programmed the
outside controller using the hub, and it worked with both the Black and
decker remote and the X10 remotes. The Black and decker remote
controlled the X10 modules. However, I assumed that once the outdoor
wireless plug was coded, the X10 transceiver would be adequate.
As long as both the X10 transceiver and b and d hub are both plugged in,
all is well, but with the b and d hub out of the loop, the X10
transceiver wont run the b and d controllers, unplug the X10 transceiver
using just the b and d hub, only the b and d sockets/modules work.
My question is this. Will the X10 transceiver all by itself run the b
and d outlets, am I doing something wrong to acheive that, or will I
need to keep both the X10 transceiver and B and D hub plugged in?
I read that the freewire stuff was programmed like the X10 socket
rocket, tried it that way, no go.
Thanks in advance for any answers
FRS from a small Eastern Canadian Seaport
Posted by dlh on May 31, 2008, 10:33 am
I have no hands-on experience with the Black & Decker stuff but this
paragraph from their manual probably explains what you are seeing.
>What is the Remote Control SYNCHRONIZATION?
>When you first install your Freewire units it is essential that your
>match up the wireless Remote Controls
>(Indoor Remote and Keychain Remote) with the plugged in Receiver Hub.
>This will synchronize their
>wireless communication in a distinct way that prevents interference with
>other Freewire systems that may
>be in your neighborhood.
My guess is that the Freewire remote can only communicate with the hub
and the X-10 transceiver will ignore it. I doubt that they would have
modified the PLC codes. Also, you need to check that the X-10 transceiver
and the outdoor units you want to control are on the same phase of your
electrical wiring. If on opposite phases, that could explain why the X10
transceiver cannot control them.
Sometimes there are more details in the FCC files for a particular
device, sometimes not. What is the FCC ID code on the Freewire remote?
Posted by J Miller on May 31, 2008, 11:52 am
I've used the BD freewire outdoor modules without the hub for a few
years. You use a x10 controller (I use a maxi) to set their x10
address. After that, they act just like any other x10 module.
The programming is a bit weird, and "kind of" documented on the module.
Within a 30 seconds of plugging it in, you send out a "x10 on" for the
address you want to use (three times, IIRC) The module says to just
hold the "on" of the freewire hub until the led stops blinking, so the
hub must be repeating the command if the button is held. With the maxi,
you must press the "on" three times...
Posted by Finlay Spicer on May 31, 2008, 1:56 pm
ah.....I never tried using the X10 transceiver to set the code on the
freewire......just their own hub.........
will give it a go.....thanx
>>> with other Freewire systems that may
>> transceiver and the outdoor units you want to control are on the same
>> phase of your electrical wiring. If on opposite phases, that could
>> explain why the X10 transceiver cannot control them.
Similar ThreadsPosted
newbie X10 Freewire Question May 31, 2008, 8:12 am
freewire question June 24, 2008, 9:43 pm
Newbie veteran question April 21, 2005, 11:43 pm
Another newbie vacation home question November 18, 2005, 8:40 am
Newbie question on external lights July 19, 2006, 9:22 am
Newbie December 14, 2005, 1:00 pm
Newbie Trying to sort it all out... March 11, 2005, 8:57 pm
Newbie: Wiring for HA April 10, 2005, 1:06 pm
Newbie Questions May 19, 2005, 11:10 am
Some questions from a HAI Newbie February 16, 2006, 6:50 pm
Help out a Crestron newbie please! June 7, 2006, 8:12 pm
newbie looking for cheap solutions April 26, 2005, 1:42 am
Newbie Advice needed May 30, 2005, 8:39 am
Best book/video for newbie? October 9, 2005, 12:32 pm
Newbie to Home Automation - Need Help November 15, 2006, 3:13 pm
