like this?
- Vote on answer
- posted
18 years ago
like this?
I need something that is guaranteed to boost X10 signals on both phases.
Any suggestions? I have lost of noise on the lines. I don't what to have special blockers on earch devices thur out the house, way to expensive to take this route.
Thanks, jt
Read this:
Boosting is not gpoing to help you.
Boosting is meant for when you have weak signal strength (less than 1volt) to re-amplify it back to 5 volts at your circuit breaker panel. If you have something emiiting noise that is at 6 volts, Boosting is not got to fix your problems. Putting more than one booster in a home is actually not good. They will actually mess up the signal and cancel each other out.
You need to find the noise source and put a filter on it. Sorry to be the bearer of bad news, but that is the answer.
