Ok, not ground-breaking, but new to me.
For those of you don't know, i've been self-installing an Elk security&automation panel [think ADT on steroids], and building out my Home Automation/Home Theater automation.
I went down a route where every single room is it's own audio zone. that means I will have 10 zones in my house, even though it's only 1650 sqft big. I just thought there would be an oppty with having room-level control, as I could automate it. I'm using a ZPR68 + EXP9 to manage the hardware-level distro. I also went down a route where I put motion detectors in every single room, incl the bathrooms. Clearly vast overkill for security purposes, but again, I just thought there'd be value in knowing if/when a room is occupied. I'm using CQC to manage both of them, as well as screen presentment to the user.
Well, I just worked something out over on cocoontech, looks like my theories may actually work out in a fashion without having to spend any more $$. I'm going to setup CQC & the Elk to turn off speakers and lighting(future) if there's been no motion in a room for 5 minutes. The design looks like it would be trivial as I could have CQC set Output208on if the familyroom speakers are turned on. In the Elk, I could then do; WHENEVER FamRmMotion IS VIOLATED AND Output208 IS ON THEN TURN Output207 ON for 5 Minutes Restart if running
WHENEVER Output207 TURNS OFF and Output208 IS ON THEN TURN Output208 OFF
I'll create a triggered event in CQC that says something like IsFldChangeFor("elk-driver.Output208?) send false to the FamRm ZPR68 Power (turn off the power in that zone)
I guess if I wanted to get complex, I could do an IsEqual("elk-driver.Output208?,False), but the only thing that'd be changing that would be the Elk.
Gotta love it when 2 seperately created, organically designed plans come together and actually have synergy.
----------------------------------------------------- Note: I am a mere end-user with no financial stake in any products that I may discuss.
My Personal Website w/my Home Automation PC:
My Home Automation Blog:
