Does anyone have experience mounting these amps in a rack? They're fairly heavy (90lbs), and ordinarily I would expect anything designed to be rack-mounted that weighs this much to have rails for a four-post rack.
I noticed in picking the amp up that the center of gravity is only a couple of inches behind the front faceplate, and I wondered if maybe it *is* safe to rack-mount it by the front ears only--they're pretty substantial.
So, anyone have experience mounting one of these by the rack ears only? Or how did you support the rear?
Thanks, Heath
