Im having some difficulty trying to make a circuit. I want to create a desk lamp which only switches on/off when you wave your hand across the sensor.
I will be using
4x AAA batteries 1.5v Each 1150mAh 8 LED 3.6 Forward Volts - 20mAh 120 ohm ResistorsNot sure about the sensor and other components..
Please can someone help me specify the materials and circuit layout.
Thanks
